We need to download the course from the Ministry of Finance https://minfin.com.ua/currency/
1. There is integration with them, but the Ministry of Finance has 3 courses, medium, nbu and black
[file]17665[/file]
Tell me which one will be loaded and whether it is possible to download black
2. Connected the integration https://datapoint.center/admin/shop/integrations/integration-minfin/control/
But the download from there did not appear in the courses, tell me how to enable it
We need to download the course from the Ministry of Finance https://minfin.com.ua/currency/ 1. There is integration with them, but the Ministry of Finance has 3 courses, medium, nbu and black
Is this trolling? enter the number 1 in the api key and hope that it will work? tobish open google and type api key minfin - it's very difficult https://minfin.com.ua/developers/api/ no comment.... 1. get the key then substitute it here and you will see what rate gives api https://api.minfin.com.ua/mb/KEY/ 2. choose interbank when you insert the key
Is this trolling?
no comment....
Ustimenko Igor OneBox production wrote: Is this trolling? enter the number 1 in the api key and hope that it will work? tobish open google and type api key minfin - it's very difficult https://minfin.com.ua/developers/api/ no comment....
I didn’t hope that it would work)) I drove in to check if some actions or an item in the courses would appear, it turns out that the interbank item and the Ministry of Finance are the same, we didn’t know this
Ustimenko Igor
Is this trolling?
no comment....
