Completion calculation: Translate the process into a stage depending on the LiqPay payment status
Guys,
I ask you to calculate the revision for LiqPay, namely: you need an action at the stages with which you can transfer the process to the desired stage ("Transfer the business process to this stage if the LiqPay payment status has changed to:"). It should work similar to the actions of New Mail (For example: Move the business process to this stage if the new mail stage has changed).
Here is a link to the documentation - https://www.liqpay.ua/documentation/api/information/status/doc. It is necessary to use only final payment statuses (indicated in the picture)
Ustimenko Igor
OneBox production
OneBox CTO wrote:
4h
I wanted to clarify, when creating this action, will he have a choice of a merchant?
24.01.2022, 12:56
Yurchenko Roman Sergeevich wrote:
Ustimenko Igor
OneBox production
OneBox CTO wrote:
4h
Yes
24.01.2022, 13:36
Ustimenko Igor
OneBox production
OneBox CTO wrote:
Yes
Please issue an invoice.
25.01.2022, 12:10
Stasyuk Yulia Vladimirovna , good afternoon!
Could you send me an invoice please?
25.01.2022, 17:27
Ustimenko Igor , here's what I thought: is it possible for this action to work once every 5 minutes? I just want to play it safe in such cases, when one of the parties slows down and cron will no longer check such actions.
12.02.2022, 18:50
yes ok
16.02.2022, 00:54
Ustimenko Igor
OneBox production
OneBox CTO wrote:
yes ok
Thank you!
Already paid.
16.02.2022, 09:48
