Here is a task https://monoshop.crm-onebox.com/340839/ and there are two payments (Fig. 1) [file]11622[/file]
In Figure 2 [file]11623[/file] automation is once a minute.
It used to work, now it doesn't. Plz fix it.
Here is a task https://monoshop.crm-onebox.com/340839/ and there are two payments (Fig. 1) In Figure 2 automation is once a minute. It used to work, now it doesn't. Plz fix it.
Corrected. With new payments, the binding will be the same as before. If you need to link unlinked payments, you can check the box "If the payment is already in the system and it is not linked to the process, try to find the process using the template above and link the payment to it"
