All four types of windows are configured here
http://box2.technosite.com.ua/admin/shop/call/windows/block/
calling from this contact
http://box2.technosite.com.ua/admin/shop/users/189/
works under the access of this role:
http://box2.technosite.com.ua/admin/role/10/acl/
making an outgoing call, click-to-call,
but the outgoing call window is not displayed
[file]2963[/file]
This contact has a KyivStar phone number,
to which we receive all calls and in events everything is displayed OK
[file]2964[/file]
we call the company, to the integrated KyivStar numbers
pop-up windows of incoming calls are also not displayed
Tyndyk Maxim Vadimovich Administrator wrote: Are there push notifications from Kyivstar on the specified calls?
ummm How is it and where can I check/see it?
ummm
You showed the logs in the description here https://crm-onebox.com/support/telephony/5722-oshibka-pri-vhodyashchih-zvonkah-kievstar/#answer14902.
In the same place, look for the corresponding number by the corresponding numbers
here are the logs for the call at 12:21
[file]2967[/file]
[file]2968[/file]
there was an incoming answered and unanswered
Unanswered does not interest me - no windows are shown on past calls. On entering there is no window? Does the user have a number registered to which they call, the status is Work, are the windows turned on?
Tyndyk Maxim Vadimovich Administrator wrote: There is no window for incoming
on an incoming call, an outgoing window is displayed There is no number in the window that calls from
Tyndyk Maxim Vadimovich Administrator wrote: The user has a registered number to which they call,
registered
Tyndyk Maxim Vadimovich Administrator wrote: Work status
included
Tyndyk Maxim Vadimovich Administrator wrote: windows included?
included
here are the three events that are displayed with the right customer who called
here are the push notifications for incoming calls
what needs to be done to make the popup appear displaying the full name of the client who is calling, not the employee, whose phone is being called
[file]3058[/file]
registered
[file]3059[/file]
Work status
included
[file]3060[/file]
windows included?
included
[file]3061[/file]
[file]3062[/file]
[file]3062[/file]
registered
included
included
[file]3064[/file]
registered
[file]3065[/file]
Work status
included
[file]3068[/file]
windows included?
included
[file]3070[/file]
[file]3071[/file]
[file]3071[/file]
registered
included
included
[file]3063[/file]
registered
[file]3066[/file]
Work status
included
[file]3067[/file]
windows included?
included
[file]3069[/file]
[file]3072[/file]
[file]3072[/file]
You show in your card that everything is included, but you call another user and it doesn’t show up? Once again - give me an example of an incoming call log and a link to the problem user.
Tyndyk Maxim Vadimovich Administrator wrote: You show in your card that everything is included, but you call another user and it doesn’t show up? Once again - give me an example of an incoming call log and a link to the problem user.
i.e. click, but nothing happens I don't even know if the call is being made even though a popup should appear
call from OneBOx under this user
outgoing call popup not showing
[file]3191[/file]
Legeza Vyacheslav Valerianovich wrote: I don't even know if the call is being made
You can check it in logging (incoming request from Kyivstar). If this is not the case, you need to check with Kyivstar whether they receive a request from us to start the call (maybe there is a problem specifically with the number of this user http://box2.technosite.com.ua/admin/shop/users/189/
