Need advice on the action "Check the existence of the process on the date to plan"
In the description of the action, it is written that there is a search for an existing process in the time interval between the date to plan and execute to, and you can search for processes with a match using the additional field of the process.
As far as we can tell, the action takes one of the dates (depending on the settings) and checks if it falls between those dates of another process.
We need to make sure that the action checks both "Schedule" and "Execute by" dates simultaneously, so that if any date falls within this interval in another process, an error will pop up. It is possible?
Good afternoon!
You can try putting 2 actions at one stage, the first action will be checked by the "Schedule" date, and the second by the "Execute by" date.
Then you can go to the stage only if 2 actions do not give an error.
19.05.2022, 21:47
wow!) thank you! indeed, that's how it works.
please tell me, are there any other parameters that affect the logic of this action? for example, the date the process was created or a specific field type?
20.05.2022, 10:47
Yaryna
No, there is no such thing at the moment.
20.05.2022, 10:56
