Previously, we did a revision on the task https://crm-onebox.com/ru/support/contacts/9815-otsenit-filtratsiyu-klientov-na-po-nalichiyuotsutstviyu-bp-u-holdinga/
there are problems with a high load on the server
Duplicate the last question
Administrator wrote:
"You can make this option - before applying the filter, check the number of contacts that are filtered before this filter - and for example, if you specify 100, then we will apply only if they are less than/equal. Is this option suitable?"
if you specify 100 - you mean to specify it as a restriction in the filter settings, right?
OneBox production
"But which one to indicate - I would recommend indicating the smallest possible based on your needs. If you filter 50 contacts, then indicate them)"
the fact is that we have a need to filter all groups of contacts, the maximum number is now about 12 thousand in the group, the minimum is 1000 (testing
Previously, we did a revision on the task https://crm-onebox.com/ru/support/contacts/9815-otsenit-filtratsiyu-klientov-na-... there are problems with a high load on the server Duplicate the last question Tyndyk Maxim Vadimovich Administrator wrote: "You can make this option - before applying the filter, check the number of contacts that are filtered before this filter - and for example, if you specify 100, then we will apply only if they are less than/equal. Is this option suitable?" if you specify 100 - you mean to specify it as a restriction in the filter settings, right? Tyndyk Maxim Vadimovich OneBox production Administrator wrote: "But which one to indicate - I would recommend indicating the smallest possible based on your needs. If you filter 50 contacts, then indicate them)" the fact is that we have a need to filter all groups of contacts, the maximum number is now about 12 thousand in the group, the minimum is 1000 (testing
with the fact that I have access to 5 tasks with a prescription of 5 days, and I cannot create a single new one, so I have to close the old one and duplicate it. Is there any way to expand it to at least 10?
Shatokhina Irina wrote: with the fact that I have access to 5 tasks with a prescription of 5 days, and I cannot create a single new one, so I have to close the old one and duplicate it. Is there any way to expand it to at least 10?
don't be bullshit for such actions I will block your account restrictions are made in order not to thrash 100 topics per day
don't be bullshit
Shatokhina Irina wrote: Igor, I don’t hit 100 topics and you can see it, but there were tasks that were not taken into work for a week and of course they were not closed
Irina response time is not regulated you can buy a paid service personally from my company and you will be answered questions even without a forum via telegram
