"Required to fill in" feature doesn't always work
Congratulations!
Please help. There is a "Required to fill" function in the interface settings, but it does not work together with the "Display block with large grid" and "Display "Procedures" buttons cell size" functions.
Tell me, is there any way to fix this?
Good afternoon. There are several settings in the universal block field settings https://prnt.sc/XedZIiI0IWko
the first "Required" - if the field has no value, an error will be issued when saving
second "Required to be filled in" - opens the field for editing if there is no value there
they work regardless of the display of the block
As I see, the edit box is open. If you still need an error when saving, is it possible to put a second check mark?
30.04.2025, 10:39
Maria
Congratulations!
Thanks for the answer. The main goal is to make it visually clear whether the field needs to be filled in or not (shown in the picture).
Shown in more detail in the video from the screen - https://youtu.be/8l3IaEUUc4o
30.04.2025, 11:03
Good afternoon. Added background for elements, now it will be visible. Wait for the update
30.04.2025, 13:58
Derkach Dmytro
Congratulations!
Thanks for the help, but nothing changed(((
01.05.2025, 13:25
