Finalization of the action: "Create a salary process based on the processes closed by the employee for the last month"
If the stage is not selected or does not allow to select it, then the task is set for the starting stage of this BP. If you need to run not in the starting stage and it is impossible to change it (BP is used not only here), then you can make a choice of status, it will take 1 hour.
11.12.2024, 11:33
let him cook
OneBox production wrote:
If the stage is not selected or allows it to be selected, the starting stage of this PSU is set. If you need to start not in the starting stage and it is not possible to change it (BP is used not only here), you can select the status, it will take 1 hour.
Good. Let's do it!
I'm waiting for the count.
11.12.2024, 12:31
let him cook
If the stage is not selected or allows it to be selected, the task is set to the starting stage of this PSU. If you need to start not in the starting stage and it is not possible to change it (BP is used not only here), you can select the status, it will take 1 hour.
The bill is paid.
I am waiting for the finalization. Thank you.
11.12.2024, 15:59
let him cook
If the stage is not selected or allows you to choose it, the task is set to the starting stage of this BP. If you need to start in a different starting stage and you cannot change it (the BP is used not only here), you can choose the status, it will take 1 hour.
When can we expect improvements?
30.12.2024, 12:02
Good day. The revision is done, where should I upload it?
09.01.2025, 12:38
let him cook
Good afternoon. The work is done, where should I unload it?
https://askoart.1b.app/
09.01.2025, 14:50
