Remove items
Good afternoon
Please tell me, is it possible to remove from the order products that are in stock and products that are not in stock through actions?
In more detail, there is an order for 500 items, and it needs to be divided into 2 orders (in stock/out of stock)
Thank you!
So maybe you don't need to delete, but add from one to another?
Or are you planning to make a copy of the order and delete the out of stock item in one and the available item in the other? It seems that there is no such action at this stage - but it can be implemented in 2 hours of revision
16.10.2024, 09:52
you can use the action delete products based on selected ones, i.e. with this action you mark products as selected or not selected depending on the field/additional field of the product - https://prnt.sc/1_jKQOMpFJjT , and then delete either selected or not selected ones - https://prnt.sc/BvmrUyHr1h95
16.10.2024, 10:56
