There is an Indicators item in the business process designer settings.
[file]22802[/file]
[file]22803[/file]
[file]22804[/file]
[file]22805[/file]
[file]22806[/file]
[file]22807[/file]
[file]22808[/file]
[file]22809[/file]
[file]22810[/file]
I wonder what the developer's idea was when they added this feature?
[file]22802[/file]
[file]22803[/file]
[file]22804[/file]
[file]22805[/file]
[file]22806[/file]
[file]22807[/file]
[file]22808[/file]
[file]22809[/file]
[file]22810[/file]
Found two related actions:
[file]22802[/file]
[file]22803[/file]
[file]22804[/file]
[file]22805[/file]
[file]22806[/file]
[file]22807[/file]
[file]22808[/file]
[file]22809[/file]
[file]22810[/file]
1. Specify process indicators depending on the fulfillment of conditions
[file]22802[/file]
[file]22803[/file]
[file]22804[/file]
[file]22805[/file]
[file]22806[/file]
[file]22807[/file]
[file]22808[/file]
[file]22809[/file]
[file]22810[/file]
2. Remove process indicators
[file]22802[/file]
[file]22803[/file]
[file]22804[/file]
[file]22805[/file]
[file]22806[/file]
[file]22807[/file]
[file]22808[/file]
[file]22809[/file]
[file]22810[/file]
There is also an Indicators field that we can display in the interface
[file]22802[/file]
[file]22803[/file]
[file]22804[/file]
[file]22805[/file]
[file]22806[/file]
[file]22807[/file]
[file]22808[/file]
[file]22809[/file]
[file]22810[/file]
And fields related to indicators can be displayed in the process display table.
[file]22802[/file]
[file]22803[/file]
[file]22804[/file]
[file]22805[/file]
[file]22806[/file]
[file]22807[/file]
[file]22808[/file]
[file]22809[/file]
[file]22810[/file]
Please give examples of how indicators can be used and what is the practical benefit of this.
[file]22802[/file]
[file]22803[/file]
[file]22804[/file]
[file]22805[/file]
[file]22806[/file]
[file]22807[/file]
[file]22808[/file]
[file]22809[/file]
[file]22810[/file]
How can I use the feature in my existing projects to get the most out of it?
[file]22802[/file]
[file]22803[/file]
[file]22804[/file]
[file]22805[/file]
[file]22806[/file]
[file]22807[/file]
[file]22808[/file]
[file]22809[/file]
[file]22810[/file]
[file]22802[/file]
[file]22803[/file]
[file]22804[/file]
[file]22805[/file]
[file]22806[/file]
[file]22807[/file]
[file]22808[/file]
[file]22809[/file]
[file]22810[/file]
[file]22802[/file]
[file]22803[/file]
[file]22804[/file]
[file]22805[/file]
[file]22806[/file]
[file]22807[/file]
[file]22808[/file]
[file]22809[/file]
[file]22810[/file]
[file]22802[/file]
[file]22803[/file]
[file]22804[/file]
[file]22805[/file]
[file]22806[/file]
[file]22807[/file]
[file]22808[/file]
[file]22809[/file]
[file]22810[/file]
[file]22802[/file]
[file]22803[/file]
[file]22804[/file]
[file]22805[/file]
[file]22806[/file]
[file]22807[/file]
[file]22808[/file]
[file]22809[/file]
[file]22810[/file]
[file]22802[/file]
[file]22803[/file]
[file]22804[/file]
[file]22805[/file]
[file]22806[/file]
[file]22807[/file]
[file]22808[/file]
[file]22809[/file]
[file]22810[/file]
[file]22802[/file]
[file]22803[/file]
[file]22804[/file]
[file]22805[/file]
[file]22806[/file]
[file]22807[/file]
[file]22808[/file]
[file]22809[/file]
[file]22810[/file]
[file]22802[/file]
[file]22803[/file]
[file]22804[/file]
[file]22805[/file]
[file]22806[/file]
[file]22807[/file]
[file]22808[/file]
[file]22809[/file]
[file]22810[/file]
[file]22802[/file]
[file]22803[/file]
[file]22804[/file]
[file]22805[/file]
[file]22806[/file]
[file]22807[/file]
[file]22808[/file]
[file]22809[/file]
[file]22810[/file]
[file]22802[/file]
[file]22803[/file]
[file]22804[/file]
[file]22805[/file]
[file]22806[/file]
[file]22807[/file]
[file]22808[/file]
[file]22809[/file]
[file]22810[/file]
You can use, for example, if the user at some stage created an invoice and sent it to the client, set an indicator for this. In the list of processes, you can see that the document has already been created (or sent), and you can also see it in the process. A very useful thing, it is not necessary to create faceless stages in the BP, but simply add indicators. This is my vision of using indicators :)
Olmonic wrote: You can use, for example, if the user at some stage created an invoice and sent it to the client, set an indicator for this. In the list of processes, you can see that the document has already been created (or sent), and you can also see it in the process. A very useful thing, it is not necessary to create faceless stages in the BP, but simply add indicators. This is my vision of using indicators :)
Thank you sincerely I wonder if you have tried using multiple indicators at the same time? Is it information overload?
Thank you sincerely
Well, in your BP there are usually 2-3, well maybe 4 key stages at which it is worth putting it. If there are more than 1-2-3, I think it will be a mess and no one will focus on them
