Good day I did not find anything similar in the available actions. It is necessary to prohibit the transition to the stage, if the input payment is not added to the BP. Will there be an implementation in the future? It is very necessary
Maybe the action at the stage "Prohibit transition depending on the fields" is suitable for you? In the conditions, you can specify: Field name Not equal paid [ordersum] Then if there is no payment in process, it will be impossible to go to the stage
Olmonic Olmonic wrote: Maybe the action at the stage "Prohibit transition depending on the fields" is suitable for you? In the conditions, you can specify: Field name Not equal paid [ordersum] Then if there is no payment in process, it will be impossible to go to the stage
If you want a direct separate action, then its finalization will take 2 hours. Therefore, it is better to solve your question without further elaboration
Olmonic
