Good morning, this morning a bug appeared with the login, every minute all users and the administrator are thrown out and have to login, this makes normal work impossible - please help to solve this issue.
Our box: https://owwa.crm-onebox.com/
Good morning, this morning a bug appeared with the login, every minute all users and the administrator are thrown out and have to login, this makes normal work impossible - please help to solve this issue. Our box: https://owwa.crm-onebox.com/
No, I have a static ip address and this happened not only to me. At the moment it has stopped throwing out, but now the Global search works somehow strangely, you enter a phone number for search, a blue square appears and hangs for a long time, 15-20 seconds and then only the result appears, is it possible to somehow restart the server or our box separately?
[file]22638[/file]
[file]22638[/file]
Also, in the control panel, the load on the processor shows 200%.
[file]22640[/file]
https://owwa.crm-onebox.com/app/system-statistic/
[file]22640[/file]
[file]22640[/file]
