Procedures are not started when there is a change in the process
Configured a procedure with automations when saving the process, the procedure should be run "On any change in the process" - https://i.imgur.com/XnfROFc.png
The procedure works correctly when saving the process from the process page, or when changing it from the bulk process editing panel.
The question arises, why is the procedure not started if changes to the process are made through the "block of subprocesses" in the parent process - https://i.imgur.com/GvJNNqe.png , https://i.imgur.com/uBvRyY7.png ? Changing the value of the field is recorded in the "User Log" of the process https://i.imgur.com/A2xfKE2.png , but the procedure does not work.
Can you fix the operation of starting procedures when there are changes in the processes?
Good afternoon. Changing the additional field does not change the process. You need to somehow update one of the main process fields
25.03.2024, 13:04
Good afternoon, thanks for the explanation.
Can you evaluate the modification so that the procedures are started upon change and if additional fields are changed?
25.03.2024, 13:11
This is a very complex feature in terms of further loading; I cannot make it to change any additional field through any point in the system. I can only suggest that you make adjustments to some place where you are making a change.
Those. in this case, in the subprocesses block we will make the setting “after updating an additional field, call procedures for updating the process” and then we will pull the procedures if the setting is enabled. If it fits, the modification will take 2 hours.
Bill?
25.03.2024, 14:04
Department of Care
OneBox production wrote:
That is, in this case, in the block of subprocesses, we will make the setting "after updating the additional field, call the procedures for updating the process" and then we will drag the procedures if the setting is enabled.
Please clarify, will this setting allow you to specify several additional fields (multilists) that will trigger the process update procedures?
26.03.2024, 13:53
Do you have any complex procedures that take a long time to work? By default, I wanted to make sure that any change through the block triggers procedures if the setting is enabled
26.03.2024, 14:05
Department of Care
Do you have any complex procedures that work for a long time? By default, I wanted to make any change through the block trigger routines if the setting is enabled
Then I just misunderstood the previous comment. Thank you.
28.03.2024, 11:05
Have you already been invoiced or not yet? Exhibit if not?
28.03.2024, 12:53
Don't put it out yet, we're determining whether it's necessary to take an extension.
28.03.2024, 14:30
