BUG: Unable to create additional fields for processes and process products
Please fix as it is not possible to create additional fields for processes and process products.
I cleaned the cache, it didn't help.
In total, there are 29 fields in the database
I am creating a new field
is not preserved during storage
It is similar in other boxes. that everything works Ok.
Box link in the box
It looks like you are trying to create additional fields with keys that are already among the additional fields?
08.02.2024, 16:44
I made it so that you could see the error on the uniqueness of the identifier
08.02.2024, 17:05
Легеза Вячеслав iCOLOR OneBox
ФОП Легеза В.В.
Maksym Vadimovych Tyndyk
No
It does not
The system automatically creates an ID
And it seems that it misses the vowels when creating
That is, this may be the bug
Fix it please
10.02.2024, 12:41
Legeza Vyacheslav
iCOLOR OneBox (FOP LEGEZA VIACHESLAV VALERIANOVYCH) wrote:
No
It does not
and I claim that it is
you created an additional field, then changed its name without changing the id - and then you want to create a field with the existing id - and now you get a boolean error
please specify a different ID when creating
12.02.2024, 08:42
ФОП Легеза В.В.
thank you sincerely
i tried to create another field and it really worked
at the same time, there is a problem when the system skips letters when creating an identifier
example on the screenshot
12.02.2024, 09:37
ФОП Легеза В.В.
thank you
checked and now the system gives the necessary error
on the screenshot is an example
12.02.2024, 09:40
Legeza Vyacheslav
added a replacement for the Ukrainian "i"
12.02.2024, 09:44
ФОП Легеза В.В.
Legeza Vyacheslav
thank you!
12.02.2024, 11:20
