Integration of balances in XML warehouses (Export)
With the help of the action "Integration of balances in warehouses XML (Export)" we want to configure the unloading of data on the balance of goods. It is necessary to download the file locally, tried different options of "Path to file" and "PATH to array" data tags, but could not get the generated xml file as a result.
Please help, how to correctly configure the "Local folder" download action so that the file is generated and can be found?
Good day.
Please provide a link to OneBox where an action is configured that does not download the file for further analysis.
04.01.2024, 16:38
Maksym Vadimovych Tyndyk
OneBox production wrote:
Good day.
Good day.
Here is the link https://amigakure.crm-onebox.com/app/automatization/hour/edit/ , 2 actions have been left enabled here (one of the settings options that we tried to do), you can analyze them first.
05.01.2024, 16:23
Maksym Vadimovich Tyndyk
Good day.
Good day. tell me whether it was possible to analyze the actions from the given example? Can you tell me what needs to be fixed for the download to work?
28.03.2024, 14:32
Hello, same problem, no file is created. How do I configure this action? Integration of balances in XML warehouses (Export)
https://logist2024.1b.app/app/automatization/hour/edit/
27.11.2024, 22:36
