Changing the xml file link
Tell me, is it possible to change the link in xml, the action "Export products to Socket"? SCREEN. In this case, the name of the store (user) must be removed from the link, removed or replaced
Good day.
Unfortunately, I don't quite understand what exactly you need to replace? You have a direct link to the file according to your domain.
28.12.2023, 16:56
Maksym Vadimovych Tyndyk
OneBox production wrote:
Good day.
The link is formed correctly, there are no questions. But we need to create a duplicate of the action with another link formation, without the specified domain (the name of our store). And here is the question, is there such a possibility?
28.12.2023, 17:55
Denis,
in the integration list of Sockets /app/priceplace-rozetka/ you can choose how many integrations you need.
28.12.2023, 21:58
Ihor Susiak
The integrator wrote:
Denis,
I understand). My task is to "not shine" the company name in the second integration. And in the integration link, an xml file with the name is formed, that's why I created this question.
29.12.2023, 09:31
when you go to settings, you can change the name and link to the file.
29.12.2023, 10:54
Ihor Susiak
I am attaching a screenshot. If you mean these settings, then the link cannot be changed, it does not change
29.12.2023, 12:08
Denis, I can change the name of the file itself and the name of the export to any other, so I changed it to new.xml and saved it.
* you must select categories for export
31.12.2023, 11:03
And I can't do it. I am attaching a Gif
03.01.2024, 11:21
Denis, you can't change the name of boxing.
To do this, you can create a new one and export it there.
03.01.2024, 13:34
you can also configure manual data export to xml using the action "Integrate XML products (Export)"
There you can choose the option to export the file to ftp - and you can choose and configure the ftp you need.
*another option is to write a program that will download your file and export it to ftp as needed. I would estimate this in 2 hours of work.
03.01.2024, 13:38
yes, I meant it so that the name of the box (store) was not displayed in the xml file
03.01.2024, 15:00
