Errors in the operation of the action: Integration of XML products (Export)
Adjusted action: XML Product Integration (Export) to export products to an xml file.
But incorrect ones are extracted to the file:
- Name of goods
- Product description, etc
It looks like this action pulls some deleted data, not the actual data currently in the item cards
Please help to fix the situation.
Here is the link to the file we get:
https://icoloronebox.crm-onebox.com/media/export/product/products_lessons_icolor...
Hello.
I assume that the data is exported from the RU fields that you have not filled out.
07.11.2023, 20:44
Легеза Вячеслав iCOLOR OneBox
ФОП Легеза В.В.
Ihor Susiak
The integrator wrote:
Hello.
super interesting!
looks like you are right
I checked and for some reason Russian was the default
now it will be necessary to twist something
I will try to do export-import as an option, maybe it will help
07.11.2023, 21:33
