If in the action "Calculate and record values in an additional field" you select the field for recording the result "Additional expenses" ([costs]) from the drop-down list, and in the settings you select: Once per hour or Once per day or Once per minute, then the action is not records the result in the specified field. (Not working action.png)
[file]21529[/file]
-If saved, it works.
[file]21529[/file]
-Or specify some other with the type Additional process shelf, it also works.
[file]21529[/file]
[file]21529[/file]
Maria OneBox production wrote: Good day. Without changes, as an example process 34435. Data from add. the fields [dopolnitelnie_rashodi] are not transferred to the field "Additional expenses" ([costs]) once per minute.
Maria
Good day.
Good day.
