Improvement: add the "Move" field to the "Products by table" block
In the "Products by table" block there is a "Shipped" field, but can you make a similar field with the "Move" operation? You need to visually see information on movements in the process itself without the “Send to” function, since we often make movements.
Good afternoon. It can be done, it will take about 2 hours (the product can be moved several times, so the quantity may be greater than the quantity of product). Bill?
09.10.2023, 15:03
Care Department
Good afternoon
Yes, I understand that. Everything suits me. Exhibit it.
PS Please look at my previous request for revision dated 10/05/2023. Thanks in advance.
09.10.2023, 15:49
Good afternoon
Tell me, when can I implement this modification?
16.11.2023, 10:00
Good afternoon. Transfercount field in the process product table
05.12.2023, 12:05
Care Department
Good afternoon
Everything is working. Thank you
05.12.2023, 13:22
