Good afternoon
Additional process fields are not uploaded to XML.
Procedure https://polax-onebox.1b.app/app/workflow/3/procedure/29/
Please tell me what could be wrong?
Care Department OneBox production wrote: Good afternoon. It’s a great idea to put a PIN code on a procedure and ask them to see what’s wrong, bravo
Ouch!)) I removed it!
Care Department
Ouch!))
I removed it!
{|$customorder_Beznalichnayaoplata|} this is not the key of the Beznalichnayaoplata field - this is the key. What you wrote is a variable for documents, for example.
Care Department OneBox production wrote: {|$customorder_Beznalichnayaoplata|} this is not the key of the Beznalichnayaoplata field - this is the key. What you wrote is a variable for documents, for example.
Thanks a lot!
Care Department
Thanks a lot!
