The interface has a Block of subprocesses.
It is necessary to see in this block only those subprocesses that have a specific value that can change and that must be set in the corresponding field of these subprocesses.
Any other subprocesses in which the value is either missing or does NOT match the given condition should not be displayed.
Now I can't find how to set it up.
Please rate.
The interface has a Block of subprocesses. It is necessary to see in this block only those subprocesses that have a specific value that can change and that must be set in the corresponding field of these subprocesses. Any other subprocesses in which the value is either missing or does NOT match the given condition should not be displayed. Now I can't find how to set it up. Please rate.
Good day. It will take 2 hours to finalize the settings for filtering by the value of the additional field in the block of subprocesses. But please specify the specific block and condition that you need to filter, so that if necessary, you can adjust the assessment and make revisions later in the desired form.
Good day.
Maksym Vadimovych Tyndyk
OneBox production wrote:
Good day.
Add settings so that you can choose an additional field and specify the value in this field, in which we display subprocesses.
With another value, subprocesses are not displayed
[file]21580[/file]
[file]21581[/file]
[file]21580[/file]
[file]21581[/file]
[file]21580[/file]
[file]21581[/file]
Good day.
[file]21580[/file]
[file]21581[/file]
[file]21580[/file]
[file]21581[/file]
[file]21580[/file]
[file]21581[/file]
[file]21580[/file]
[file]21581[/file]
[file]21580[/file]
[file]21581[/file]
[file]21580[/file]
[file]21581[/file]
[file]21580[/file]
[file]21581[/file]
[file]21580[/file]
[file]21581[/file]
Legeza Vyacheslav iCOLOR OneBox (FOP LEGEZA VIACHESLAV VALERIANOVYCH) wrote: Add settings so that you can choose an additional field and specify the value in this field, in which we display subprocesses. With another value, subprocesses are not displayed
The assessment is the same.
Legeza Vyacheslav
Thank you very much
Legeza Vyacheslav
Thank you very much
Maksym Vadimovych Tyndyk OneBox production wrote: Do you need an invoice for payment of finishing touches?
not yet, I expect the Client to be ready to do so
