BUG Force stages to be created on every screen refresh
Help please
I found a swamp that I can't even describe properly
1. Added several statuses to the process
2. When I refreshed the screen, they all matched and closed the start status
3. It seems that every subsequent update of the screen adds more statuses with the same names
Now a whole stack of statuses with the same names has accumulated
I will send a link to the process to the developer's mail
Легеза Вячеслав iCOLOR OneBox
ФОП Легеза В.В.
Everything worked and it's very good!
Thank you very much to whoever took the time to fix this bug
But, I decided to use the opportunity and made a video, which I posted with access Not for everyone.
https://youtu.be/qardUxN4EJ4
It's called: When I posted a request on the OneBox forum, they didn't answer me, but it seems that the error has been fixed, thanks
By the way, the cache was clean then and now.
The browser is the same.
That is, there are no questions for the browser that it could be the cause of what you had to face when configuring the process
20.09.2023, 10:59
ФОП Легеза В.В.
You can close the topic as if the problem has been solved.
20.09.2023, 11:00
Legeza Vyacheslav
you may have resaved the form
Legeza Vyacheslav
Everything could be parallel (no one could not see your theme when changing the functionality) - that's how it happened.
Legeza Vyacheslav
You can close.
26.09.2023, 09:26
ФОП Легеза В.В.
Maksym Vadimovych Tyndyk
no, I didn't save the form again
added stages one time
the form closed
Duplicate stages in packages began to appear every time the screen was updated
at this stage, which I added through the form, I ALREADY managed to paint
everything can be
26.09.2023, 21:54
