Automation stopped working Universal import of products (xml/json)
In the https://blokpost.1b.app/ box, since the 26th, products from feeds that we download with automation once an hour "Universal import of products (xml/json)" have stopped being downloaded (and updated). In the logs we can see the result of working https://i.imgur.com/9Yt1dQx.png (The file is not available or is empty)
The same settings were made for another box, in it the file was downloaded and successfully processed by the system https://i.imgur.com/hycafLx.png
Please tell me why the file may not be uploaded to the box https://blokpost.1b.app/ ?
Vasylyk Taras
Good day.
Because the host from which the file should be downloaded is not available from the box server:
ping kapterka.com.ua
PING kapterka.com.ua (93.190.142.105) 56(84) bytes of data.
^C
--- kapterka.com.ua ping statistics ---
7 packets transmitted, 0 received, 100% packet loss, time 5999ms
# traceroute kapterka.com.ua
traceroute to kapterka.com.ua (93.190.142.105), 30 hops max, 60 byte packets
1 gateway (172.31.1.1) 2.570 ms 2.545 ms 2.553 ms
2 16479.your-cloud.host (136.243.180.227) 0.457 ms 0.460 ms 0.468 ms
3 * * *
4 spine7.cloud2.fsn1.hetzner.com (213.239.230.145) 8.452 ms spine8.cloud2.fsn1.hetzner.com (213.239.230.149) 1.211 ms 1.629 ms
5 spine1.cloud2.fsn1.hetzner.com (213.239.239.37) 1.285 ms spine1.cloud2.fsn1.hetzner.com (213.239.239.101) 1.270 ms spine2.cloud2.fsn1.hetzner.com (213.239.239.105) 45.664 ms
6 core24.fsn1.hetzner.com (213.239.239.133) 0.871 ms 2.330 ms core24.fsn1.hetzner.com (213.239.239.129) 0.546 ms
7 core4.fra.hetzner.com (213.239.224.90) 5.102 ms 4.845 ms core4.fra.hetzner.com (213.239.224.74) 4.838 ms
8 static.213-133-121-130.clients.your-server.de (213.133.121.130) 5.070 ms 4.976 ms 4.969 ms
9 109.236.95.102 (109.236.95.102) 12.928 ms 16.718 ms 12.999 ms
10 109.236.95.231 (109.236.95.231) 16.478 ms 20.012 ms 16.307 ms
11 * * *
12 * * *
29 * * *
30 * * *
29.08.2023, 12:12
wget "https://kapterka.com.ua/index.php?route=feed/universal_feed&feed=oneboxfeedc...
--2023-08-29 12:12:31-- https://kapterka.com.ua/index.php?route=feed/universal_feed&feed=oneboxfeedc...
Designated by name kapterka.com.ua (kapterka.com.ua)... 93.190.142.105, 2a00:7c80:0:27::1108
Connecting to kapterka.com.ua (kapterka.com.ua)|93.190.142.105|:443...
curl: (28) Failed to connect to kapterka.com.ua port 443 after 127264 ms: Couldn't connect to server
failure: Connection timed out.
we can't download the file from the box server. Sergey Vladimirovich if it's a cloud https://blokpost.1b.app/desktop/, can you see why the file isn't downloading? Lokalka gives, but there is no grit connection
29.08.2023, 12:16
