Add field to XML export automation
Here https://univer.1b.app/app/automatization/hour/edit/
in the action "Integration contacts in XML (Export)" you need to add the system field "Client group" for unloading.
How many hours do you need to implement?
1h if just separated by a comma or 2h if there is a setting on how to unload if there are several groups. Separated by commas or several identical tags side by side
10.07.2023, 13:39
There is always an option without modification - to automatically copy groups to the additional field with the action "Fill the field of the contact card based on another field")
10.07.2023, 14:11
Susyak Igor
integrator wrote:
There is always a no-hassle option
it is always there, but some people fortunately understand what this leads to in the end (to 100+ actions of automating contacts and saving a card in 10 seconds instead of 0.5) and prefer a fast system to a slow one.
10.07.2023, 14:30
Третяк Артур
Care Department
OneBox production wrote:
Susyak Igor
Gold, not words)
Care Department
Just separated by a comma with a space. And another moment. Add a multilist type setting which groups to upload. That is, to choose which contacts will be uploaded based on their groups. There must be all groups, and by default, if empty, then all are unloaded. And also, the fad should be "Without a group", so that it could also be downloaded separately. How many hours do you need?
10.07.2023, 15:39
Those. make 2 settings:
1. Select contact groups + item No group. If groups are selected, then only contacts of the selected groups get into the export file, if not selected, then we unload everything as it is now. 1 hour
2. Ability to upload the names of contact groups to a file separated by commas. 1h
10.07.2023, 15:48
Пятецкий Николай Николаевич
Insiders - OneBox
Care Department
Yes. Card account plz.
And the moment is, whether it will be possible to correct what would be extra. fields were loaded not in a separate array, but in the same array as the system fields?
As an example in processes where PATH to add. fields are specified through "/".
10.07.2023, 16:10
"PATH to the array of additional fields" in this setting, specify / or the same path as in the main array, one of the options should work in theory
10.07.2023, 17:51
Третяк Артур
Care Department
And so and so tried. Does not help(
Apparently, this functionality is missing in this setting.
11.07.2023, 14:01
I will add within those 2 hours. Have you already issued an invoice for this task?
11.07.2023, 14:11
Insiders - OneBox
Care Department
Thank you.
Have just paid
13.07.2023, 14:02
settings in action:
Select groups. If groups are selected, only users of these groups will be unloaded
Allow empty path to array of additional fields
Contact groups - field in the list of fields to upload
19.09.2023, 12:49
