Tell me why the hourly action may not start when we select the "start hourly action within a few minutes" check box, i.e. the check box was selected and clicked to save, but the action does not work, i.e. the uploading of information does not work, and this is a problem not only with one action, but with by all
[file]20633[/file]
What can be connected with this problem?
[file]20633[/file]
[file]20633[/file]
Bohdan Alexandrovych Luts VANBOX CORP wrote: Congratulations! Do you have the hours specified in the action when the action should work?
Good day No, it is not specified, and the problem is not in a specific action
VANBOX CORP wrote:
Congratulations!
Good day
Then try to insert the application https://1b.app/ua/app/system-statistic/ But on the main page, look at the last time cron-hour worked https://tppr.me/5jyBM When you click on the button "Detailed information" from the very top there will be information about how long it works
Bohdan Alexandrovych Luts VANBOX CORP wrote: Then try to insert the application https://1b.app/ua/app/system-statistic/ But on the main page, look at the last time cron-hour worked https://tppr.me/5jyBM When you click on the button "Detailed information" from the very top there will be information about how long it works
we do not advise on the mvp version
Previously, we had a server with little RAM, then we added more memory (increased by 2-3 times)
But the problem was not solved, the hoster said that it is necessary to add memory
It seems that there is such a process "coon-minute-external.php" and there it is indicated in the parameters (there is a file on the server /etc/cron.minute.conf.sh) "memory_limit=256M" and apparently it does not have enough of these 256M to perform its work
When you try to make changes to the "/etc/cron.minute.conf.sh" file, i.e. change "memory_limit=256M" to "memory_limit=1G", the changes are made, but after a couple of minutes, the file returns to the old value again.
Can you tell me how to correctly change the memory_limit for cron.minute?
It shows that it did not work last time
[file]20639[/file]
It seems that the problem is in memory
[file]20639[/file]
[file]20639[/file]
[file]20639[/file]
[file]20639[/file]
[file]20639[/file]
[file]20639[/file]
[file]20639[/file]
The problem was solved, it turns out that the problem was in the limits Information for those who will have similar problems: changed "memory_limit" in the file "cron.minute.conf" + "cron-mine.minute.conf" which are located in the directory "var/www/boxname/web1/web/" i.e. increased RAM usage limit and as a result everything worked.
Yulia wrote: The problem was solved, it turns out that the problem was in the limits Information for those who will have similar problems: changed "memory_limit" in the file "cron.minute.conf" + "cron-mine.minute.conf" which are located in the directory "var/www/boxname/web1/web/" i.e. increased RAM usage limit and as a result everything worked.
There is one more nuance that the system overwrites the data in fals once a day: cron-main.day.conf cron-main.hour.conf cron-main.minute.conf It provides some reference data Therefore, you need to make copies of these files and add ".custom" to the end So that it turns out: cron-main.day.conf.custom cron-main.hour.conf.custom cron-main.minute.conf.custom After that, the system should already take the "memory_limit" data from the ".custom" files
cron-main.day.conf
cron-main.hour.conf
