Please check why the action Create a task for all contacts of the order that we use in the procedure CATEGORICAL PROFILES TO PARTICIPANTS does not work
[file]20607[/file]
When tested, the action with the same settings worked and created subtasks for process contacts.
[file]20607[/file]
[file]20607[/file]
[file]20607[/file]
I understand that this is a duplicate of the topic https://1b.app/ua/forum/business-processes-and-automation/17234-ne-vistavlyayutsya-zadachi-na-kontakti-protsesu/ where I gave a recommendation.
yes, it's the same question on different boxes it seems that the problem was not in the check box explained in the previous topic
Maksym Vadimovych Tyndyk
