Guys, we need improvement and your help in the issue of Payments and Suppliers.
Very often I encounter the same situation when the same Supplier has many different organizations (FOP) and because of this I cannot correctly set up obligations (both in the context of one FOP and for the Supplier as a whole), + in the very ordering, it is not convenient to work with the Supplier, it is not clear which sole proprietorship needs to be paid.
It is not convenient to create a supplier for each FOP, + this entails a lot of other manual work related to the "Minimum reserve", "Brands", etc.
Therefore, I ask you to consider such a refinement (if you see another solution to this problem, I am happy to listen):
- When displaying a pop-up in the "Payments" block (displayed when you click on "Last payments of the client"), display payments for all subsidiaries of the client, + add a column with the name of the organization itself.
Plus, it would be convenient if you could somehow highlight the organization that was chosen for this BP
Here is a detailed video https://youtu.be/N3SB7jJNYo8
Guys, we need improvement and your help in the issue of Payments and Suppliers. Very often I encounter the same situation when the same Supplier has many different organizations (FOP) and because of this I cannot correctly set up obligations (both in the context of one FOP and for the Supplier as a whole), + in the very ordering, it is not convenient to work with the Supplier, it is not clear which sole proprietorship needs to be paid. It is not convenient to create a supplier for each FOP, + this entails a lot of other manual work related to the "Minimum reserve", "Brands", etc. Therefore, I ask you to consider such a refinement (if you see another solution to this problem, I am happy to listen): - When displaying a pop-up in the "Payments" block (displayed when you click on "Last payments of the client"), display payments for all subsidiaries of the client, + add a column with the name of the organization itself. Plus, it would be convenient if you could somehow highlight the organization that was chosen for this BP Here is a detailed video https://youtu.be/N3SB7jJNYo8
Yurchenko Roman Sergeevich wrote: Therefore, I ask you to consider such a refinement (if you see another solution to this problem, I am happy to listen): - When displaying a pop-up in the "Payments" block (displayed when you click on "Last payments of the client"), display payments for all subsidiaries of the client, + add a column with the name of the organization itself.
It can be improved so that when withdrawing payments for child employees / companies in the payment pop-up, display a specific payment client, and not the parent organization - this will take 1 hour
Yurchenko Roman Sergeevich wrote: Plus, it would be convenient if you could somehow highlight the organization that was chosen for this BP
I think similarly, you can modify the highlighting of the selected organization with some color - it will also take 1 hour
Tyndyk Maxim Vadimovich OneBox production wrote: Good afternoon.
Thank you. Submit an invoice
Good afternoon. 1. In the "Last customer payments" pop-up, payments for all child contacts of the order customer are displayed, and in the "Customer" column, the corresponding customer is displayed from the payment 2. In the holding company structure block, a setting for selecting the background color of the selected company has been added
Tyndyk Maxim Vadimovich OneBox production wrote: 1. In the "Last customer payments" pop-up, payments for all child contacts of the order customer are displayed, and in the "Customer" column, the corresponding customer is displayed from the payment
Good afternoon Unfortunately, it doesn't work for me. Can you suggest what exactly am I doing wrong? Here is a screen demo https://youtu.be/0mApgn_S2JQ
Tyndyk Maxim Vadimovich OneBox production wrote: 2. In the holding company structure block, a setting for selecting the background color of the selected company has been added
Everything is there and working. Thank you!
Good afternoon
Yurchenko Roman Sergeevich wrote: Unfortunately, it doesn't work for me. Can you suggest what exactly am I doing wrong? Here is a screen demo https://youtu.be/0mApgn_S2JQ
Good afternoon. Tell me, are there any payments in the system for the specified child client? Can I have an example?
Good day!
Yes, I have. Here I filtered payments on it https://our-store.com.ua/app/payments/?clientid=54543&clientid=54543&ok=%D0%A4%D0%B8%D0%BB%D1%8C%D1%82%D1 %80%D0%BE%D0%B2%D0%B0%D1%82%D1%8C
Tyndyk Maxim Vadimovich OneBox production wrote: Check now, everything works correctly in my opinion.
Now everything works PERFECTLY! Thanks a lot!
