Example, the product has a price from the supplier in USD
If "Input price currency" is NOT SELECTED in the process product field, then when the rate changes in the "process currency rate" block, the input price changes depending on the specified exchange rate.
If in the field of the product of the process SELECT currency USD "Input price currency", then when the rate changes in the "process currency rate" block, the input price does NOT change depending on the specified exchange rate.
Example, the product has a price from the supplier in USD If "Input price currency" is NOT SELECTED in the process product field, then when the rate changes in the "process currency rate" block, the input price changes depending on the specified exchange rate. If in the field of the product of the process SELECT currency USD "Input price currency", then when the rate changes in the "process currency rate" block, the input price does NOT change depending on the specified exchange rate.
Maksym Vadimovych Tyndyk OneBox production wrote: Good day. Explain why you think this is a mistake? 2 fields are available to you - price and currency - what you set is what you have.
That is, the logic is the opposite. When we select "Input price currency", the exchange rate does not change. When there is NO currency in "Currency of the input price" then the exchange rate is UPDATED.
Good day.
