Is it possible for the employee to receive a message only in the case of a comment sent for him (via @) in BP?
That is, if someone simply wrote a comment in BP without linking the employee (via @), then there is no message.
Is it possible for the employee to receive a message only in the case of a comment sent for him (via @) in BP? That is, if someone simply wrote a comment in BP without linking the employee (via @), then there is no message.
Good day. We can finalize the settings in the system according to a similar logic - it will take 4 hours. For example, the logic can be as follows - when adding a comment to the process, if the responsible process is specified, create a message to the message center only to the responsible stage and the author of the process, otherwise - to all observers of the process. And if an employee is mentioned in the comment, a message will also be created for him to the message center. If interested, we can issue an invoice for finalization, or also listen to your corrections in the specified logic.
Good day.
Maksym Vadimovych Tyndyk OneBox production wrote: Good day. We can finalize the settings in the system according to a similar logic - it will take 4 hours. For example, the logic can be as follows - when adding a comment to the process, if the responsible process is specified, create a message to the message center only to the responsible stage and the author of the process, otherwise - to all observers of the process. And if an employee is mentioned in the comment, a message will also be created for him to the message center. If interested, we can issue an invoice for finalization, or also listen to your corrections in the specified logic.
An interesting decision, you need to think. In the meantime, thanks for your reply.
Good day.
