please tell me which action updates the contact field type date
Good day.
Please tell me which action updates the contact field type date "Update".
When moving to a stage, the "Update" field must be updated in the contact card.
Samokhin Vladislav
we are talking about the udate field of a contact, which action can update the udate of a contact (just now the action changes an additional field and we need the udate field of the contact to be updated as well)?
11.05.2023, 15:16
udate is automatically populated when updating almost any of the contact's base fields. For example, if you replace his full name, company name, gender, date of birth, etc.
12.05.2023, 12:45
Samokhin Vladislav
Poltorak Sergii wrote:
udate is populated automatically when updating almost any of the basic contact fields. For example, if you replace his full name, company name, gender, date of birth, etc.
but in our case, the action "Fill the process or contact field" changes the additional field, and the udate field does not change... and it needs to be changed, because it is configured to synchronize it with 1s...
a mechanism is needed so that the udate field is updated when additional fields are changed due to an action...
12.05.2023, 14:42
You have 2 options:
1. Add a second action that will change some base field
2. Modify this action so that it changes udate, 1h.
12.05.2023, 14:50
Samokhin Vladislav
where can I see the list of basic fields?
12.05.2023, 15:02
no such documentation exists. In the universal contact block, you can see all the fields that start with user. https://skrinshoter.ru/p/120523/9ed0go , in 90% of cases this is the base field
12.05.2023, 15:21
Samokhin Vladislav
thank you very much. while I will try 1. Add a second action that will change some basic field
I will use a field that we do not use.
Good day!
12.05.2023, 15:25
Thank you and have a nice day too.
12.05.2023, 15:38
