Is it possible to use any variables in addition to additional fields in the "Write value in the product field depending on the fulfillment of conditions" action?
In the testing process, it turned out that only additional fields can be used in this action (on the minute crown) "Write the value in the product field depending on the fulfillment of the conditions".
The hint states: You can use the key of an additional product field, for example [custom_XXXX] . The variable does not work for category, brand and currency.
When trying to write an action in the test field [custom_test] / [articul] / [brandname] / [id]
Did not write anything, i.e. wrote blank (cleared previous values)
These variables [articul] / [brandname] / [id] work in product automation, but here it turns out not to work, it's just strange why it cleared the field.
1. Which fields can be used in this action except custom (additional)?
2. Why, when there are non-custom fields in the "Value" field (for recording), the system clears the field altogether and writes blank?
In the testing process, it turned out that only additional fields can be used in this action (on the minute crown) "Write the value in the product field depending on the fulfillment of the conditions". The hint states: You can use the key of an additional product field, for example [custom_XXXX] . The variable does not work for category, brand and currency. When trying to write an action in the test field [custom_test] / [articul] / [brandname] / [id] Did not write anything, i.e. wrote blank (cleared previous values) These variables [articul] / [brandname] / [id] work in product automation, but here it turns out not to work, it's just strange why it cleared the field. 1. Which fields can be used in this action except custom (additional)? 2. Why, when there are non-custom fields in the "Value" field (for recording), the system clears the field altogether and writes blank?
1. For comparisons, almost any product field. brandid categoryid unit currencyid price and other 50 fields. 2. Probably because nothing else can be used If you need to fill in something with something specific, it's better to ask "I have a task XXX, how to complete it." That will be more efficient.
1. Can you write several values in the "Value" field, that is, glue two fields into one? For example, set the following formula: [custom_tekst1] / [custom_tekst2] And so that the result in the product, for example, was "Text Field1 / Text Field2" 2. In the field, you can calculate formulas, for example [custom_pole3] + [custom_pole4], so that, for example, if the value [custom_pole3] = 3, and [custom_pole4] = 4, then the result in the product was = 7, that is, the system added fields and recorded the result does the system only use value substitution (converting to text)?
3. You wrote above that you can use the variable: price, when you enter [price] in the field in this format in the "Value" field, the system wrote the same [price] in the product, that is, it did not replace it with the price, how to correctly write these variables about did you write "brandid categoryid unit currencyid price and other 50 fields ...." ? 4. Can these variables "brandid categoryid unit currencyid price and other 50 fields..." be viewed in the universal product block?
1. What's stopping you from trying? 2. What's stopping you from trying? 3. An example with automation and a link to the product, please 4. see points 1, 2
4. see points 1, 2
Tried it, but somehow it doesn't work correctly, if one variable works, it still seems to work normally, if two, then I either cut off the chatina or leave it open. Before writing, they tried several times with different settings Our MVP is thinking of switching to the OS, you said that it is not supported, so probably the problem is in the MVP Perhaps we will try to repeat on the demo OS and then give a link to the product
