Good day, when you go to automation you can see that there are prescribed automatic actions. But when, for example, you directly switch to automation once an hour, it is empty. This applies to all three typical atomizations
[file]19836[/file]
[file]19837[/file]
[file]19836[/file]
[file]19837[/file]
[file]19836[/file]
[file]19837[/file]
did not change anything, as there is no understanding in this. Everything from the box or if it is the rule then only Onebox. Automation works within the limits of those actions that were there. But when you go directly to a specific automatic action, then it is empty (a minute, an hour, or once a day). Plus, you can't add anything new. Try it
