For unknown reasons, empty tasks with the following description began to be automatically created at the same time and in different statuses:
[file]19623[/file]
An example of a process to display the operation of the program
[file]19623[/file]
Screen 1340
[file]19623[/file]
Instantly, the system is filled with junk.
[file]19623[/file]
Please fix this.
[file]19623[/file]
Because if someone really needs to create such tasks, he will create them himself.
[file]19623[/file]
[file]19623[/file]
Screen 1340
Please fix this.
This is done on purpose to fill the system with data with examples of tasks that can be created. If you do not need them, select - delete. This only happens if you have an empty box without a single task in it and you install the crm app in it.
[.dev #82] now it is clear why they did that but why put several tasks in the same status? by the way, the number of records affects the capacity of the data used :) in my case, it is about 27 empty and unnecessary from the point of view of solving problems and it seems that if there were 30 stages in the business process, of which 15 are the entry points of the business process, and 5 are the exit points, then there would be much more tasks than now 90, or how many ;)?
[.dev #82]
90, or how many ;)?
I don't quite understand what these questions are about. What difference does it make how many there are. Create a box for yourself, create one simple task in it, then start setting up the bp if you don’t want to see unnecessary tasks.
Legeza Vyacheslav Valerianovych iCOLOR OneBox (FOP LEGEZA VIACHESLAV VALERIANOVYCH) wrote: [.dev #82] now it is clear why they did that but why put several tasks in the same status? by the way, the number of records affects the capacity of the data used :) in my case, it is about 27 empty and unnecessary from the point of view of solving problems and it seems that if there were 30 stages in the business process, of which 15 are the entry points of the business process, and 5 are the exit points, then there would be much more tasks than now 90, or how many ;)?
realized that no one particularly cares about the amount of data ;) that the user receives when he starts using the system
[.dev #82]
90, or how many ;)?
