Variable {|$basketsArray|}name
Tell me how to specify the desired language in the variable {|$basketsArray|}, namely {|$b.name|}? Because different cases require a different language for the product name.
Good day!
At the moment, there is no such possibility, the system takes the name of the product in the language by default.
27.03.2023, 16:28
Bohdan Alexandrovych Luts
VANBOX CORP wrote:
Good day!
Thanks for the answer. Maybe there is an opportunity to make a finishing touch? Tell me how much it could cost?
27.03.2023, 16:31
Good afternoon. You can take the name from the product card, do it in separate variables. Takes 1 hour to finish.
27.03.2023, 18:27
VANBOX CORP wrote:
Good day!
Good day!
Thank you. Issue an invoice
27.03.2023, 18:29
Good afternoon. The work has been uploaded. An example of how variables work:
{|foreach from=$basketsArray item="b"|}
ua: {|$b.nameua|}
ru: {|$b.nameru|}
{|/foreach|}
28.06.2023, 14:40
Good day!
Everything works. thank you
28.06.2023, 21:48
