https://solidenglishschool.1b.app/24739/ set up a block of subprocesses to display tasks for a deal. If the block is on top, it displays the tasks if it is lowered under other blocks. then there will be no result. There will be an empty block in the transaction. And bringing it back up doesn't help. need to make a new block
[file]19581[/file]
[file]19580[/file]
[file]19581[/file]
[file]19580[/file]
Derkach Dmytriy OneBox production wrote: Please describe in more detail. Nothing is clear from the description.
As described, the subprocesses block did not display tasks in progress if the block was not on top in the interface, but under other blocks, as in the screenshot
Derkach Dmytriy
Is the problem still relevant? I can't repeat this on 2 projects
in the process that I threw off, it also does not display, I did not change the settings if you have already corrected this error. You can look at this
[file]19931[/file]
Derkach Dmytriy
[file]19931[/file]
[file]19931[/file]
[file]19931[/file]
[file]19931[/file]
[file]19931[/file]
I just moved the block up - and everything is displayed, what's wrong?
in that it does not display subprocesses being at the bottom. as it is now on the screen, it is empty. And if the block is on top, then there are tasks
[file]19944[/file]
Derkach Dmytriy
[file]19944[/file]
[file]19944[/file]
[file]19944[/file]
[file]19944[/file]
[file]19944[/file]
