There is an employee of "Vasya" with 2 roles "leader" and "manager"
In the Universal process block, I hide the block for the "manager" role.
In this case, the "Vasya" employee does not see this block.
Why so? how to make it possible to see the block from a role that is not prohibited?
There is an employee of "Vasya" with 2 roles "leader" and "manager" In the Universal process block, I hide the block for the "manager" role. In this case, the "Vasya" employee does not see this block. Why so? how to make it possible to see the block from a role that is not prohibited?
because you prevented the Manager role from seeing the block.
Polupan Sergiy Anatolyovich wrote: Why so? yak zrobiti so schob s role of yak is not fenced, bachiti block?
In this case, no way. You can make a setting to block the block to all managers who do not have the "XXX" role, for example. So you can select the desired role from "Vasya" and show the block in this way. By default, "Vasya" is the same manager as everyone else and he is forbidden to see this block, why is he better than others? You can also make a separate role "Can't see the block" and select it for all managers and not select "Vasya", and select the same role in the universal block. This way you can hide it for other "managers"
Why so?
Polupan Serhii Anatoliyovych wrote: Why so? how to make it possible to see the block from a role that is not prohibited?
In this case, no way. You can configure it to block the block to all managers who do not have the "XXX" role, for example. So you can choose the role you need and show the block that way. By default, "Vasya" is the same manager as everyone else and he is forbidden to see this block, how is he better than others? Also you can make a separate role "Can't see the block" and select it for all managers and not select "Vasi" and select this role in the universal block. So you can hide it from the rest of the "managers"
thanks for the answer
.dev
OneBox production wrote:
Why so?
