For some reason, balances are not shown correctly if you select an employee in the "stock" column
1 line - it can be seen that there are goods in both warehouses.
But if you select the composition of a specific employee, it shows 0 (zero)
[file]19003[/file]
For some reason, balances are not shown correctly if you select an employee in the "stock" column 1 line - it can be seen that there are goods in both warehouses. But if you select the composition of a specific employee, it shows 0 (zero)
