Good afternoon, we need an evaluation of the completion of this action: "Change the business process and stage depending on the fulfillment of the conditions for the values of several fields" - add that the action works not only once a minute, but also when switching the stage. Because now it thinks for 1 minute. for each inspection, if there are 7-10 of them in the process, he thinks for a long time, but I do not see such an action with "but".
[file]18650[/file]
Good day! I recommend that you use the action Change process and stage fallow by field value , it has the ability to set several actions, set the "Not Equal" condition, and there are also different options for launching actions
Good day! I recommend that you use the action Change process and stage fallow by field value [file]18651[/file] , it has the ability to set several actions, set the "Not Equal" condition, and there are also different options for launching actions
