Dia "Add contacts to the tab Contacts process" add one and the same contact dekіlka razіv so the contact is known to dekіlkoh groups one hour
Nalashtovana diya "Add contacts to the tab Contacts to the process", in it a dekіlka of groups was collected for some research work.
if contact is found in dekilkoh groups at once, then yogo add to the skin group in a row
Dali diya "Mass mailing email for all contacts process" pushing one and the same contact dekіlka listіv
How can you fix it?
Dia "Add contacts to the tab Contacts process" add one and the same contact dekіlka razіv so the contact is known to dekіlkoh groups one hour Nalashtovana diya "Add contacts to the tab Contacts to the process", in it a dekіlka of groups was collected for some research work. if contact is found in dekilkoh groups at once, then yogo add to the skin group in a row Dali diya "Mass mailing email for all contacts process" pushing one and the same contact dekіlka listіv How can you fix it?
