In the di ї "Fence the transition in the fallow land in the field of irrigation" the logic is wrong (because I don’t understand)
If the mind is beaten, then you can go to the stage, although the description says "if they all win, then you will see a pardon and you will not be able to go to the stage"
Tse pardon in the description?
Oleksandr, good afternoon
Please describe in more detail which ban you need to set and the action screen as you have configured it.
14.11.2022, 10:30
Гуляєв Олександр
Друкарня "Друкарик"
Sorry, didn't paste the screenshot.
Here it works correctly with these settings
If a legal entity = KP, then it goes to the next stage - that's what I need.
But in the description it is written that if the legal entity = KP, then an error will be issued.
That is, everything is the opposite.
14.11.2022, 13:54
everything is correctly described in the document, just to check the legal entity, you need to specify its ID, not its name
14.11.2022, 14:16
Гуляєв Олександр
Друкарня "Друкарик"
Tried through Idi. It didn't work out.
Test Order #34137, in which the legal entity "2" went to the stage "Issue + Rec. KP", although at this stage there is a prohibition to go if the legal entity is not equal to "1"
15.11.2022, 09:02
and you can reset the screenshot of the inretface block, what exactly is the field you have displayed, since there is a legal entity of the process, and there is a legal entity of the contact
since I checked on Not exactly , everything works
15.11.2022, 09:08
Гуляєв Олександр
Друкарня "Друкарик"
Yur. person
(order.order_contractorid)
15.11.2022, 11:02
Yur. person
action checks the contact field
Entity
(user.user_contractorid)
15.11.2022, 11:11
Гуляєв Олександр
Друкарня "Друкарик"
Of course.
There is no action that checks the Process Person?
One customer can have different legal entities in different orders.
15.11.2022, 11:17
"Calculate and write the value in an additional field if the conditions are met" there are settings to prohibit transition if the conditions are not met
i.e., if the transfer is allowed only when the legal person=1, then I specify the condition legal person=1 in the action, if the condition is not fulfilled - prohibit the transfer
15.11.2022, 11:28
Гуляєв Олександр
Друкарня "Друкарик"
I did it, but it doesn't work.
Issued the permission to proceed to the "Issue + Rec. KP" stage, if legal person=1 (CP)
I'm pushing the stage "Vidat. + Rach. KP"
An error occurs and the stage does not go
15.11.2022, 12:43
specify the name of the legal entity
15.11.2022, 12:56
Гуляєв Олександр
Друкарня "Друкарик"
You had an aidi above.
I will try now.
It is surprising that the actions in the stages are somewhat limited. ONE action can be written only in additional fields, another in additional and contact fields, but not in process fields. Why didn't you just do it: all actions can write to all fields. There are a lot of actions, it is difficult to search. It was possible to reduce their number and collect complex actions from simple actions
15.11.2022, 13:03
Гуляєв Олександр
Друкарня "Друкарик"
Now everything works.
15.11.2022, 13:08
