How to fill the contact field with decalcom multilist type with values?
Vikoristovuyu dіyu "Restore the field for the process or contact" Ale nіyak not go to write dekіlka value.
Is it possible?
Is it possible for you to win the victory as another day?
How to fill the contact field with decalcom multilist type with values? Vikoristovuyu dіyu "Restore the field for the process or contact" Ale nіyak not go to write dekіlka value. Is it possible? Is it possible for you to win the victory as another day?
Andriy wrote: "Fill in the process or contact field"
Good day. You can specify multiple values with a delimiter (for example ;), and then in the "Split values by delimiter" setting, specify ; and when writing to a multilist, everything should be written as it should be.
Good day.
