Congratulations! I have a problem: I created an additional field of process products, wrote down the formula for its calculation, but it is not calculated. Tried to set the automatic calculation action at the stage, but the field is also not calculated. Maybe I wrote the variables in the formula wrong. Tell me how to write them down correctly.
Order screen
[file]18101[/file]
Field settings screen
[file]18102[/file]
Screen of variable codes
[file]18103[/file]
[file]18098[/file]
[file]18099[/file]
[file]18100[/file]
Congratulations! I have a problem: I created an additional field of process products, wrote down the formula for its calculation, but it is not calculated. Tried to set the automatic calculation action at the stage, but the field is also not calculated. Maybe I wrote the variables in the formula wrong. Tell me how to write them down correctly. Order screen
In this field, you can use the process subfield and the process product field, just the process product field cannot be used You can try using the action "Calculate and write the value in an additional field" with the formula: [orderproduct_sum]-[orderproduct_paidsum]
