It is necessary to refine the search for a product and pre-clean the process from products
Here https://univer.1b.app/app/automatization/minute/edit/#done
There is an action "Integration of XML processes (Import)".
1. You need to clean all products before updating.
2. You need to implement search and adding in a non-standard way https://take.ms/j82sh :)
As a result, it should turn out that each update of the process has new data from the file.
How many hours do you need to implement?
1. to clean the products of the process? WTF? why?
2. this is straight shit structure ..... you'd better correct it at the source so that the identifier is duplicated
bo refinement of such nonsense hours 6
01.11.2022, 17:49
Пятецкий Николай Николаевич
Insiders - OneBox
Ustimenko Igor
But if. Shaw maєmo then maєmo :(
Post an account plz.
03.11.2022, 16:23
