Incorrect work of the action "Check fields filled"
https://www.loom.com/share/397a953c7b704d6291ea96b4c621473f in the video showed the example of a checkbox error. If you check only what is displayed, then it does not check for required fields at all, if you should consider zero as filled, then the lists do not check for filling , and empty lists are passed to the stage.
2) The second mistake is that when displaying CRM orders, it sometimes bugs and asks you to select a business process and you either need to clear the cookies, which clogs again after a couple of transitions, or something else.
Анатолий
Интегратор
06.10.2022, 14:22
1. About the checkbox "check only what is displayed" - it checks for the interface that is configured for the current stage. You use the interface from the 1st status, either save it for all stages with the button, or for this stage
about payment and delivery methods. You check the box to consider 0 as the value that is populated.
The delivery method and the payment method in the database have the data type integer (integer), so when the value in the list is not selected in these fields, then the value in the database is 0.
to resolve this issue, simply divide your checks into 2 steps, in 1st specify check the method of payment and delivery, unchecked with 0. In another with a checkmark and other fields
2. like the question is not relevant?
22.11.2022, 17:00
Анатолий
Интегратор
Ustimenko Igor
Thanks for the reply, but
1) checked, it does not work the same, for all the interface is applied https://www.loom.com/share/1a09cf15039c469490a9c87be36f83af
22.11.2022, 18:53
Anatoly
Consulting company "Sales Bureau" wrote:
Ustimenko Igor
did you go to the interface settings of the stage where the action is and saved the interface there?
until I see it
22.11.2022, 18:57
Анатолий
Интегратор
Ustimenko Igor
Anatoly
Ustimenko Igor
until I see it
https://www.loom.com/share/06bceefdfd6b41f59336f8f86c7e3520 I did it on purpose, at this stage, the mandatory field also does not work
and I did not know that you need to save the interface at each stage personally, at first you yourself said "apply for all stages"
22.11.2022, 19:08
Anatoly
Ustimenko Igor
Anatoly
Ustimenko Igor
until I see it
in general, I understand what the problem is. There are different grids in the interface, and the action was done for a regular grid, while it did not take into account others. I added grid accounting, check if it works now?
22.12.2022, 18:51
Анатолий
Интегратор
Ustimenko Igor
Anatoly
Ustimenko Igor
Anatoly
Ustimenko Igor
until I see it
https://bestorg.1b.app/801/ you can check, I resaved the interface and actions .. and still does not offer to fill
23.12.2022, 16:07
