Возникают сложности в работе системы? Есть непонятный момент в настройке? Рекомендуем обратиться к нашим партнерам-интеграторам - они с радостью вам помогут в настройке!
Посмотреть список партнеров
https://1b.app/ru/forum/business-processes/13979-bag-ne-otkrivaetsya-prilozhenie/
There is a problem with the application again.
https://ergo.crm-onebox.com/app/workflowtype-00-obrashcheniya/
If you select the display method "Tile", then the application stops opening.
[file]15884[/file]
Please help fix this problem.
Ustimenko Igor OneBox production OneBox CTO wrote: if you removed smarty tags correctly, then everything would be ok well, you yourself broke everything get high))
Oops, apparently some kind developer removed this tag very very sorry
Ustimenko Igor
OneBox production
get high))
very very sorry
