Возникают вопросы по работе системы? Вы всегда можете обратиться к вашему партнеру-интегратору и он поможет в решении сложности. Если у вас нет партнера-интегратора то мы подготовили для вас список.
Посмотреть список интеграторов
Good day
Once again, run "Link products from the supplier process to the current process, if there are enough of them"
https://orc-test.kiev.ua/admin/shop/workflow/35/procedure/76/?status=0
for example, in process 16752
product is not listed until 16633
The task is to shove and bind the goods, yakі є in the postal worker's engagement, to the in-line engagement.
Good day Once again, run "Link products from the supplier process to the current process, if there are enough of them" https://orc-test.kiev.ua/admin/shop/workflow/35/procedure/76/?status=0 for example, in process 16752 product is not listed until 16633 The task is to shove and bind the goods, yakі є in the postal worker's engagement, to the in-line engagement.
Good afternoon. You have a Gostomel warehouse, there is a balance of this product on it, and therefore the action does not work. If you do not need to account for these balances, write off the goods from this warehouse.
