Sorting bug by quantity of ZA products in stock
Sorting only works with ungrouped data (there are checkboxes in the left panel, show balances in separate entries, etc.)
26.08.2025, 17:30
Брикайло Юрій
He drinks fuel like it's free
OneBox production wrote:
Sorting only works with ungrouped data (there are checkmarks in the panel on the left, show balances as separate records, etc.)
Thank you for your answer.
Made using an additional product field.
Works on grouped ones too.
26.08.2025, 17:59
Randy Marsh Original comment available on version: ua
In case of a small number of warehouses this will work without problems if you just copy the rest of the product to them
27.08.2025, 11:32
