Bug with barcode printing
For some reason, the variable {barcodeimageexternalean13} displays a different barcode than the one specified in the product card.
The problem so far is only with one product https://one-box.shine-bright.com.ua/app/product/6811/edit/
its code is 7612412428286, but the print output is 7612412428285
and this shk corresponds to another product https://one-box.shine-bright.com.ua/app/product/6802/edit/
Barcode 7612412428286 is not valid for EAN13 format https://barcode.tec-it.com/en/EAN13?data=7612412428286 https://prnt.sc/FfKRVh7Ppjeo
the variable barcodeimageexternalean13 takes 12 digits of the barcode and forms the 13th number - the checksum, you can see that it will be exactly 5 https://prnt.sc/0eJ-j-jsU3i_
Donats 1
3 USD from Родион
27.12.2024, 09:31
oh, got it, thank you very much
27.12.2024, 17:28
