Evaluate the possibility of implementing the refinement of the bar coding function
It is necessary to create a separate program in which you can read the bar code of the product using the phone's camera and it is possible to see information about the availability of this product in the warehouse in a pop-up window. It should also be possible to create a business process for this product in the warehouse.
the scanner is in the Vanbox OS mobile application
everything else needs a detailed description, because it is all possible and can be configured now
30.04.2024, 23:09
