What do we do:
[file]21842[/file]
[file]21843[/file]
[file]21844[/file]
1. The goods were placed in the warehouse.
[file]21842[/file]
[file]21843[/file]
[file]21844[/file]
2. When the goods were sold, a bar code was prescribed for the product in the warehouse
[file]21842[/file]
[file]21843[/file]
[file]21844[/file]
3. We store the product in our warehouse with a barcode.
[file]21842[/file]
[file]21843[/file]
[file]21844[/file]
4. You need to find and add this product to the process in order to destock the product
[file]21842[/file]
[file]21843[/file]
[file]21844[/file]
BAG
[file]21842[/file]
[file]21843[/file]
[file]21844[/file]
The product cannot be found and added to the process by barcode in the warehouse, the system gives an error
[file]21842[/file]
[file]21843[/file]
[file]21844[/file]
Product by barcode not found
[file]21842[/file]
[file]21843[/file]
[file]21844[/file]
To search by barcode, use the block:
[file]21842[/file]
[file]21843[/file]
[file]21844[/file]
Product search by barcode with settings as on the screen
[file]21842[/file]
[file]21843[/file]
[file]21844[/file]
Please help to fix the existing error.
[file]21842[/file]
[file]21843[/file]
[file]21844[/file]
[file]21842[/file]
[file]21843[/file]
[file]21844[/file]
[file]21842[/file]
[file]21843[/file]
[file]21844[/file]
[file]21842[/file]
[file]21843[/file]
[file]21844[/file]
What do we do:
BAG
In this block of the process Search for product by barcode, a search is performed using the barcode specified in the product card, in the product filter value, additional fields (if the setting is specified). Barcodes in the warehouse are not searched. It can be modified to also search by barcode in the warehouse and, if such a product is found, write this barcode also in the product field of the process such a revision in 1 hour
Maria OneBox production wrote: In this block of the Product search by barcode process, a search is performed by the barcode specified in the product card, in the value of the product filter, additional fields (if the settings are specified). Barcodes are not searched in the warehouse. It is possible to refine what to look for in the same way by the barcode in the warehouse, and if such a product is found, record this barcode also in the field of the product of the process such revision in 1 hour
What do we do: 1. The goods were placed in the warehouse. 2. When the goods were sold, a bar code was prescribed for the product in the warehouse 3. We store the product in our warehouse with a barcode. 4. In the Search product by barcode block, enter the barcode of the product in stock 5. Automatically, this product is added to the process to write it off from the warehouse Bill, please.
Maria
What do we do:
Bill, please.
Thank you sincerely as promised, a small gift from me :)
Maria
Warehouse barcode search setup added to block https://prnt.sc/-nFoSQUiivXW
Thank you sincerely
